Guest viewing is limited
Leaking Saniflo Sanicompact.
View the thread, titled "Leaking Saniflo Sanicompact." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have had a Saniflo Sanicompact for 11years. It has been little used and never for solid waste. I have noticed recently that water is seeping out between the base of the pan and the floor. I have checked all the accessible hose clips etc. but all are tight and dry. The water appears to be coming from the macerator which I cannot see without removing the Saniflo and upending it.
Most likely to be a jubilee clip worked loose.
[automerge]1574452565[/automerge]
Wouldn`t be the black tube that pokes out of the lefthand side leaking would it and is it clean water?
Reply to the thread, titled "Leaking Saniflo Sanicompact." which is posted in UK Plumbers Forums on Plumbers Forums.
Hollywood,
rpm,
