View the thread, titled "Leaking toilet cistern" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all, further to my replacement of a cictern syphon, I have a small leak I can not seem to sort out. I have tightened the plastic nut as tight as I dare as I expect it is close to snapping.
What can I do to stop the leak please as my wife is now seriously not impressed with me replacing a damp towel every day in the bathroom!
Either leaking from the bolts eg through the cistern
https://www.NoLinkingToThis/p/euroflo-close-coupling-cistern-bolts/48787
Or as above new donut
I replaced the donut, removed and replaced the whole lot twice and it still leaked!
The bottom of the cistern has a crack, visible only from peering inside with the lid off so I wondered if there is a hairline crack. I have got so frustrated I tightened up the nylon bolts pretty tight so I might have messed up there.
Anyway, I put silicon over the length of the crack and left it for 2h and it has been OK since so I hope that now lasts for a few years.
Thanks to you all for the help
Oh crap! It's still leaking but very slowly
The story continues!
  1. Leaking more
  2. We then got a plumber in - I know, what a failure!
  3. He's replaced the plastic stuff with metal, added some white mastic, new washers etc.
  4. It was still leaking. He came back and sorted it.
  5. It is still dropping 5-10 drops a night down the spindle of one of the screws and I have tightened and loosened the butterfly bolt to no avail (in fact I tightened it too much initially and the washer started to get squished out the side)
I am defeated - he hasn't sent a bill in to us (a week ago now) so I think he wants no more of it LOL
My current idea is a new cistern
I think that this was inevitable once you found the split in the existing cistern (post #5). Once started, cracks propagate until they hit a boundary and silicone is at best going to be a temporary measure.
Yeah maybe, the plumber seemed to think it was sound but I think it must be cracked after all these attempts.
Last question then is does anyone recognise this cistern please as we need to match ideally as we now have vinyl floor down?
New cistern advisable but if you feel up to one more attempt give the bottom of the cistern a "skim coat" of Puraflex 40. It's my favorite failsafe stick and fill almost anything to anything and I've fixed water tanks with it and all sorts.
Thanks, I'll pop to B&Q today to look for that. There was a load of similar in the cistern so it may have been like this for a while before we moved in.
Reply to the thread, titled "Leaking toilet cistern" which is posted in Boiler Advice Forum on Electricians Forums.
