Biffa Lad
Hi All
Im no plumber but wanted some guidance on a small issue I have.
I have a towel rail installed in my bathroom and it is leaking very very very slightly on the bottom of the valve where the pipe from the GCH fits into the bottom of the valve.
I am sure it probably needs some more tape applying to the thread to make it water tight. My question is, How can I do this without making a right mess with water as soon as I loosen it slightly the water starts to increase, which is obvious I guess.
Is there an easy way to do this without the need to drain either the entire system ??
As you can tell Im no plumber 😱)
Cheers
Cheers
