Hi, Was called to a five storey house converted into flats for a customer who is tanking his ground floor flat and has discovered the gas was run in copper and then buried under his flat. At some points it is just run straight in concrete. There is a need to rerun them all but I can't find anything on the legality of them continuing to pass through his flat.
Planning will not allow the gas to run up the front of the building which is where the meters are and which would be the easiest option. The best option I can see is to run them in Tracpipe in screed under his flat then Copper up the back of the building to each flat. Is this allowed?
