6 year old Vaillant ecotec pro with vertical flue in a close to inaccessible loft space, full length of flue is about 2.5m with one Of The fittings inside the inaccessible loft space, perfectly viewable from an access hatch. The flue has all of the screws in where it is supposed to, nicely patched in at the ceiling below, good lead slate above but there is no support bracket in the loft space where there should be, however the flue is not loose.
Checked the flue integrity which was perfect so I deemed this not an AR situation.
What would you have done?
