R
ruthn85
I moved into a rented property a couple of months ago. The heating has never been right. Never had a problem with the hot water though.
The timer setting doesn't always work. (I put the pins down - heating doesn't come on).
If I turn it on to "constant on" the heating comes on BUT cuts out after a certain amount of time.
When the timer does come on it also cuts out.
The room thermostat doesn't work, so it isn't this that is cutting off the heat. (I have fiddled with it and reset and re-linked it, changed batteries etc).
Every so often I have to turn the boiler off at the main switch to get it to do anything! It works fine for a few days and then all these issues start up again.
Please help! I'm getting really annoyed with it!
