View the thread, titled "Looking for this type valve" which is posted in Find Local Plumbers - Post a Job on UK Plumbers Forums.
W
Will_D
Hi all, Hope you can help me out.
I need to source a number of these valves:
Basically its a push button type that allows a flow of gas. A bit like the old fashioned brass blow-down guns. I have found a modern blow gun that would work but would prefer this simple valve.
It is about 5 cms long and is threaded 1/4" bsp or so ( as is American its actulally and NPT size ! )
The tread is not overly important but its "push the button to squirt the" gas is!!
If any one can steer me in the direction of a link then would be most grateful.
Cheers
Will
Gas is CO2 at about 10 psi. Its for filling beer bottles ( called a counter-pressure bottle filler - like what the big boys use )
Maybe able to source in USA but then ther's postage and customs to consider.
( I did like the discovery channels gun-smith program about the flame throwers mounted on a truck - just to compare Napalm FF versus the Petrol/Diesel mix )
Now this post will probably set off the alarm bells in the Pentagon and GCHQ ( Oops - just done it again )
Will
same as this really.......
[DLMURL="http://www.powerfit.co.uk/epages/ny33m8en93tj.sf/en_GB/?ObjectPath=/Shops/ny33m8en93tj/Products/PREVOST_PCL/SubProducts/PREVOST_PCL"]QUICK RELEASE SAFETY COUPLINGS ONE PUSH PCL BRITISH TYPE - POWERFIT[/DLMURL]
Reply to the thread, titled "Looking for this type valve" which is posted in Find Local Plumbers - Post a Job on Plumbers Forums.
