Danny1234
Would appreciate any help before calling out central heating engineer.
GlowWorm 12hxi condensing boiler has been losing pressure. Every morning pressure is at 0bar so I top up to 1bar cold.. Fire up boiler works ok but pressure drops down to 0 bar throughout the day, this has been going on for about 1 year. Cable tied bag over PRV outlet pipe left it there for 3 weeks totally dry so not a problem with PRV leaking. I have access to every inch of pipe work, both when boiler is running hot and cold I have visually looked for leaks but found none. Boiler loses pressure even when not in use. I can top up pressure to 1.5bar in the morning, not switch boiler on for a whole day by next morning back to 0bar. I once repeated topping up boiler every day for two weeks when not using central heating to see if I could find any wet/damp patches on any rad/pipe joins or around boiler but found no sign of leaks. The other day I disconnected the condensate drain pipe where it connects to my sink waste I placed the end over a bucket, pressurized the boiler to 1.5bar did not fire up boiler left it switched off. Condensate drain pipe started to drip water. I calculated that about 700ml of water was coming out of condensate drain pipe in a 3 hour period. My question is should the condensate drain pipe leak water if the boiler is not in use and had not been in use for a 24 hour period. Could this also be responsible for the pressure loss?. I’m also getting a lot of air in system.
Any help would be greatly appreciated
All the best
Danny
All the best
Danny
