Loss of pressure in unvented central heating system.
View the thread, titled "Loss of pressure in unvented central heating system." which is posted in Central Heating Forum on UK Plumbers Forums.
K
kristy22
New Valiant ecoplus 438 wall hung condensing boiler. Hot water cylinder, on first floor. Pressure vessel in loft, Pressure drops in vessel approx 1 bar per day. Does not appear to be due to pressure relief valve. No leaks apparent. System has been running for 3 months and is a combination of old pipework in house and new in extension. Any suggestions as to cause of pressure drop please,
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Welcome to UKPlumbersForums.co.uk kristy22. Thanks for introducing yourself.
you either have a leak somewhere in the house or a faulty expansion vessel,it does not take much of a leak to drop pressure in a sealed system,are things like your rad valves up to it?are they 10 bar?
if I ran my system at 10 bar everything would give upwhy do rads valves have to be 10 bar? max I want to work at is 1-21/2 serious question here not sarcasm
dont know,i advise everybody to fill there boilers to 1 bar when cold especially if its a he boiler,they say rad valves are built to 10 bar to cope with pressurised systems
Thank you so much Gasman for this usual info. It is all a nightmare at the mo!! Appreciate your expertise.
Reply to the thread, titled "Loss of pressure in unvented central heating system." which is posted in Central Heating Forum on Plumbers Forums.
kristy22,
kristy22,
