View the thread, titled "Low water pressure on unvented syetem." which is posted in Bathroom Advice on UK Plumbers Forums.
M
Mikeydoes
3 days ago I partially drained the central heating on an unvented system to fit some TRV's. It refilled okay and everything worked fine but now the domestic water pressure has dropped to a mere trickle. Does anybody think there could be a link between the 2 or just a coincidence. If the how water tank needs to be looked at I will need to get an unvented qualified plumber to check it.
Thanks.
Think you have a problem with the cylinder, it could be a simple fix like a blocked filter or it could be somthing else, anyhoo, if you don't have the G3 ticket then get a bloke in who has.
Reply to the thread, titled "Low water pressure on unvented syetem." which is posted in Bathroom Advice on Plumbers Forums.
