View the thread, titled "macerator" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
lenny
can anybody advise me what size waste pipe compact macerator toilets use.
thanks 🙂
As said down to 22mm but this is not ideal, I have had to unblock many because elbows have been used go for the largest pipe you can otherwise problems for the future.
The sanoflow is 22mm but many of the other makes are 1 1/4",so would use the larger as said and keep your options open on unit used and you will not be tied down on any replacement units in years to come
thing is with 22mm, your able to get your mouth around it and give it a good blow to get the blockage out.😉
Thanks for the replies,
I collected the macerator on Sat the manual recommends 32 or 40mm plastic.
Reply to the thread, titled "macerator" which is posted in UK Plumbers Forums on Plumbers Forums.
