MagnaClean Atom Installer Feedback
View the thread, titled "MagnaClean Atom Installer Feedback" which is posted in Independent Plumbing Course Feedback on UK Plumbers Forums.
At Adey, we are always looking for feedback for our products. What are your thoughts of our MagnaClean Atom filter? With its ultra low profile design, that allows our installers to install a MagnaClean in previously inaccessible places.
Adele
dont use them use plumb centres own which is made by you and cheaper
either that or pro 2s
I also find it hard to justify to a customer that they need to spend about double the cost of many other brands of mag filters to buy the Magnaclean.
It is good, but still just a piece of plastic, 2 brass iso valves and a strong magnet.
Especially when they present you with a list of things and how much they can buy them for - Thanks Mr Interweb!
Adele , I love magnas , not tried the atom yet.
Only problem I have and I have posted this problem earlier in here tonight is non magnetic particles get through . I am aware this is a problem with all magnetic filters but cant your boffins come up with something, ( pre -filter built in maybe )
Try the twin tech 😉
Adele
Haven't used one yet Adele. The only place I've seen one was on YouTube when PB did a small review on them, nice and compact and I have an upcoming job where one would be beneficial, unfortunately with the boiler packs I buy from Grahams the atom isn't listed as an option so I will likely use a pro 2 instead.
The 3’s seem a bit mental, what do you think ?
Fitted a few atoms. I really like them. My only slight negative is that you can’t plug a flusher onto them. Unless there’s a method I’ve missed
I guess it wont be cheap but I am interested in seeing what it actually tells you about the system. Does it just notify when it needs cleaning out or doesn't monitor the water acidity too.
Adey Magnaclean as a unit is probably as good as several other filters on the European market ..I designed some others but cannot self promote Lou told me off. I would go for
centramag by Trappex , a great filter mag and non mag fikter produced by a fella that put his house up to get it on the road
and Shaz is also a nice man
Magnaclean tried to wipe him out...they failed to beat him then myself and my Mr Clement helped him
Adele
why can Adey self promote when I cannot ?
One for Rob, I came up with an idea many years ago to remove large particles from a heating system AND it’s not a filter.
I’ve actually got several ideas, for tools and everyday plumbing devices that would help us all on a daily basis.
And they would work
Maybe I should pull my finger out and actually build the god damn thing
Hi Bog if you want to progress your idea We are quite happy to
go over it and issue an NDA before we start and involve you at all stages. We also will tell you if its a non starter or non commercial ...There are never any up,front fees ...your call
private msg if you want to
Rob Foster centralheatking
Reply to the thread, titled "MagnaClean Atom Installer Feedback" which is posted in Independent Plumbing Course Feedback on Plumbers Forums.
Adey,
diy plumber,
