View the thread, titled "Main 30 HE losing pressure after central heating heating been on" which is posted in Central Heating Forum on UK Plumbers Forums.
Good Afternoon folks. Thanks in advance for any advice.
I have a main 30 HE Combi. It loses pressure down to zero after the central heating has been on. If I start the day on 1 bar, it holds fine. Run the hot water/have a shower etc pressure goes up, then returns to 1 bar when turned off and holds.
If I put the central heating on the pressure goes up to just over 2 bar. Will stay for about 30 minutes then start going down. When heating finishes cycle the pressure keeps going down to zero. Fill it up via the loop to 1 bar when cold and it holds perfectly.
Can't find any leaks. Was wondering if anyone had any ideas.
Have a look outside there should be a copper pipe that’s roughly exiting near the boiler rubber band with a plastic bag over the end
does it fill up with water ?
Reply to the thread, titled "Main 30 HE losing pressure after central heating heating been on" which is posted in Central Heating Forum on Electricians Forums.
