Main combi 24 HE, heating starts and stops
View the thread, titled "Main combi 24 HE, heating starts and stops" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All, Hope someone can help with this one too. Main combi 24 HE, heating fires up as normal then stops after about 30 seconds. Any thoughts? Hot water works fine.
Nice and vague. Does it restart again? Doesnit d it continuously or just once and then nothing? Do you get an error code at all?
Definitely say the Diverter or the motor then. If rads are getting hot, then either the motor isn’t moving or the Diverter pin is stuck, since you’ve replaced the Diverter on a whim, I’d say the motor. You could confirm this by testing with a mm.
Reply to the thread, titled "Main combi 24 HE, heating starts and stops" which is posted in UK Plumbers Forums on Plumbers Forums.
nip_it_up,
Deleted member 120897,
