View the thread, titled "Main Combi 30 HE" which is posted in UK Plumbers Forums on UK Plumbers Forums.
davlin
Hi there
Can anyone advise.
My boiler is only 2 years old and my hoy water supply is not constant.
with the hot tap on full my boiler is at full fire for 30 seconds then goes off for 10 seconds and so on. Central hesting side seams fine.
Cheers Davlin.
likely diaphragm faulty,obviously cant tell you how to repair it but a easy job for a competent plumber or gsr engineer
was system flushed out when boiler replaced,sounds like maybe plate heat exchanger blocked,overheating
As said will have to get someone in
It was a complete new system and fernox added. Tried changing DHW diaphragm in diverter valve, and temp probe,made no difference.
When boiler fires up on DHW only, pipe to C/H supply is boiling hot.
Try local gas safe engineer or Baxi website for a local fitter.
You have been without hot water for a week now and have just guessed at parts to change, not good.
Reply to the thread, titled "Main Combi 30 HE" which is posted in UK Plumbers Forums on Plumbers Forums.
