The how to reduce the pressure as even cold water comes with all lot of pressure in taps and whenever water is used the water pipes make noiseTurning the stopcock slightly closed will not reduce the pressure. It will reduce the maximum flow rate.
Thanks I got the point. I will still need the key in emergency as may need to stop the supply.Turning the stopcock slightly closed will not reduce the pressure. It will reduce the maximum flow rate.
Pressure reducing valve reduces pressure. Stopcock could be the plastic keyboard type.
Reply to the thread, titled "Main Meter Stopcock key- How to identify" which is posted in UK Plumbers Forums on Electricians Forums.
