C
clankypipes
I was hoping to get a professional opinion regarding whether or not a booster pump (such as a Stuart Turner 'Flomate') would do what I want it to do.
At present the flow rate in our house isn't terrible - about 10 litres per minute at its best - but that doesn't seem to go far if more than one tap is turned on. The biggest problem is that if you are having a shower upstairs and someone else turns on a cold tap, the flow through the combi boiler drops below the level at which it will work, and you lose hot water completely. And if, alternatively, you are using the electric shower downstairs, then the same thing happens when a tap is turned on, the flow rate dropping below the level at which the the shower will function.
I only recently found out that in-line boosters exist. They claim to add up to 1.5 bar of pressure, and guarantee a flow rate of 12 litres per minute. I am guessing that adding one to the mains pipe coming into the house wouldn't actually make a huge difference. But what if I add one just for the hot water and downstairs bathroom? Like this...
Would this set-up prevent the hot water from cutting out in the situations described? I realise that this may end up meaning that the other taps in the house are starved of water whilst someone has a shower, but this seems like a better situation than the current one.
Any advice would be greatly appreciated.
On a separate note, I can only find two options for the pump: the Flomate mentioned above, and the Salamander 'Home Boost'. Does anyone have any experience of either / recommendations / warnings etc? The Stuart Turner one seems to have a better guarantee and is slightly cheaper.
Thanks in advance!
Thanks in advance!
