View the thread, titled "Making a diy decarbonizing heater for my bbq gear??" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
mutley racers
Subscribed
So just a thought, do you think it is possible to use a 40ltr garden waste bin by just putting an immersion heater in the lid and just put a plug on the cable and plug it into a socket for in my garage? Maybe set it to 50degrees? Am pretty sure the plastic would not melt at this temperature.
What do you reckon?
If so, can you buy a female tank connector this side?
I hate scrubbing bbq stuff!!!
Or maybe use a stainless steel bin?
Ideas would be great
also, whats grade D? I get ya i think, fold the cylinder in where i cut it
Grade D plumbers solder
Sold in 1lb bars, 30/70 tin/lead used for wiping joints. Drill a 2½" hole, tin (apply solder) about an 1½ around the hole. Stick the immersion (it is made of brass) in and wipe a joint with grade D (a bit greasy thin cardboard will do to wipe with if you don't have a moleskin). Cheaper than an essex flange :wink:
If your immersion is too long bend it in 2. Just don't go too tight on the radius but it willl bend tight enough to fit through the hole.
Simples as they say :lol:
Reply to the thread, titled "Making a diy decarbonizing heater for my bbq gear??" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread starter
mutley racers
Subscribed
Joined
Location
Hampton court, Surrey
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
heater
mutley racers,
zzzjim,
