Hi all,
I’ve recently moved into a house and want to start using a fireplace that hasn’t been used in around 10 years. The fireplace has a back boiler which has since been disconnected when the central heating system was revamped a few years ago. We currently have solar panels and an oil boiler, but since we have a back boiler already in the house it would be good if we could make use of it to lower our oil usage over winter.
The problem is that, for reasons I won’t bore you with, the fireplace is in the upstairs of the house and the hot water cylinder is now in the downstairs of the house, almost directly underneath where the fireplace is.
Is there any way we can utilise the back boiler? My understanding is that it cannot be connected to the hot water cylinder as it is the wrong orientation for a gravity feed to work, but I’d be happy even if it only fed the radiators in the two bedrooms, also upstairs, as we would likely only be lighting fires once we are home for the evening. It just seems a shame that we have a back boiler sitting in our house but can’t get any benefit from it.
Obviously I would have a professional check the safety of the fireplace and back boiler before going ahead with anything, just wanted to know what is possible as I can’t seem to find any information relevant to this situation online.
Thanks,
Ben
Thanks,
Ben
