I’ve already solvent fixed it the opposite way to what you have suggested - hence my concern when I looked down it and saw the smaller dia part of the flexi as per pics.Fit it as I suggested then you'll be fine, any hairs should catch in the shower trap and be able to be cleaned out ?. Kop
I just use the 1" 1/2 one as I didn't even know about the internal restriction. You may be over thinking it, the water will flow towards the compression end and not into that reduction for my typical installationThanks for that - celotex is a good call!
The Flexcon6 which is for inch and half pipe has a reduced internal diameter that looks around inch and a quarter - is this ok for bath or should i fit the 2 inch Flexcon8 ? - I'm worrying about that internal dia blocking!
Reply to the thread, titled "McAlpine Flexcon flexi connector" which is posted in UK Plumbers Forums on Plumbers Forums.
