View the thread, titled "Metal sink repair" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
F
fogarty
Has anybody used the metal repair stuff you can buy. Need to do a temporary repair on a pinhole in a kitchen sink.
Belzona/liquid metal on the underside if its accessable, it'll last for ages provided its applied as per mans ins
Tho it will probably cost more than a new sink
Have used Liquid metal in a tube from car accesorie shop on cast before lasted for months until I changed the leaking section regards Turnpin:smug2:
Changed a bath once that had temp repair 10 p stuck over hole with LSX held up for two months....not my repair though lol regards Turnpin:smug2:
if its just a temporary repair dow corning silicone will do if its a pin hole they are probably putting neat bleach into the sink before the water rather than water then bleach
They've just moved house and can't afford to replace sink before Xmas. Think something sharpe been dropped on it to be honest.
Reply to the thread, titled "Metal sink repair" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
