micro bore system
boiler is down stairs
ho****er cylinder, air separator, pump and zone valve are in the loft conversion, f and e tank is directly above
went 2 weeks ago and found a massive airlock at the top which had completely starved the pump of water, big section of pipework from the feed pipe to below the pump was totally dry
no work had been done on the system, thought it was vey strange that an airlock had suddenly appeared, couldnt figure out where it had come from, checked float valve in the f and e, checked rads for air etc, thought if it had a leak why wouldnt the system simply fill up again with water not air. had no idea where it was drawing this air from
sucked the airlock out with a wet vac put in new pump and put it down to just one of those things, however got to return tomorrow morning as apparently its happened again
feed and vent
old pump and air seperator
didnt take any other pics as i wasnt expecting to be going back
![20140303_181300[1].jpg 20140303_181300[1].jpg](https://ukplumbersforums.co.uk/data/attachments/14/14682-35f15afcd6997a0d68d321bb6919abcf.jpg?hash=NfFa_NaZeg)
![20140303_181253[1].jpg 20140303_181253[1].jpg](https://ukplumbersforums.co.uk/data/attachments/14/14683-03936bf7fd42a6b80346aa8dda32f7ad.jpg?hash=A5Nr9_1Cpr)
