G
gmac
Hi all,
Having a bit of a problem with a microbore heating system, carried out a chemical flush, f3 added a week ago and returned to drain out and refill adding corrosion inhibitor, done all that and fired up the heating and checked radiators where heating ok, all but one heating 100%, the rad furthest from the pump, checked balancing and all l-s's fully open so shut all down to bare minimum and all but that one continue to heat fine.
Turned all radiators off except the one causing problems and as expected came upto temperature top and bottom of radiator, circulating fine, when turning other radiators back on the problem radiator started losing heat again.
The radiator in question is approx 16x69 dpc and 10mm run from 22mm drops, 10mm run approx 8-9m each way.
Any ideas
Any ideas
