We have a very tight gap between the top of our skirting board and the bottom of the window, 510mm. We have researched and and taken delivery of a couple of 3 column Milano Windsor radiators (500mm). Unfortunately the brackets for wall mounting are sloped and extend beyond the bottom of the radiator and we can't fit it (with brackets) is the gap (this is not obvious from any of the dimensions on the website). To avoid cutting into the skirting, or buying radiator, feet we are looking to some universal column radiator fixings (which attach in the same way as the Acova range). Does anyone have any experience of this or can recommend any particular fittings? Are any of the other brands cross compatible (e.g. Acova?)
