My Clerk of Works pal has a cotractor installing new Domestic Hot Water Storage Tanks in flats. Thety are positioned above the Hot Water Cylinder but are only about 150mm from the ceiling tut tut. I have mentioned that im sure its dictated as minimum 400mm from top of tank to allow for maintenance to be carried out to ballcock etc,. I have spent hours lookingat the water regs but cant find the regulation dictaing distances. can someopne ploease help or confirm 400mm minimum distance.
I Thank You.
Martin
I Thank You.
Martin
