View the thread, titled "Mira combi flow shower not heating up" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
T
thomo34
Hi all
I have a combi boiler a Baxi 28HE PLatinum and a Mira Combi Flow shower , the shower has stopped giving out hot water , it appears that when the shower starts the boiler isnt firing up to heat up the water.
Water from the taps works fine.
The issue can be resolved by turning the boiler off and resetting it but when left to the evening/morning the same happens again
any helpwould bemuch appreciated thanks
Check the filters on the shower, see if shower head is scaled.
The usual suspects.
ah ok ,well i have removed the shower head and Ididnt see any real sign of dirt , however when the shower was started up it did heat up a lot quicker than before so thanks for the advice.
The flame symbol on the boiler didnt light up when the shower was running hot , is it supposed to because imwondering if it ever did , or does it just stay on until the water is at the temp set by the controls on the boiler ?
Reply to the thread, titled "Mira combi flow shower not heating up" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
