Mira select ev shower
View the thread, titled "Mira select ev shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
64degrees
Got a customer with Mira Select exposed valve shower - cartridge shot and replacement over £150 so may as well replace. Seen that a new Select EV over £300, any ideas on a cheaper alternative ?
Cust reckons the pipe centres 150mm, don’t want to leave holes on tile when swap it out, standard bar won’t suit.
If it's Mira I suspect your pipe centres will be 153mm not 150 which will cause you an issue.
You can get a Mira Element at Screwfix for 200+VAT
https://www.NoLinkingToThis/p/mira-...xposed-chrome-thermostatic-mixer-shower/454fv
Thanks for this, haven’t seen been to the job, had a vague memory the centres were off. Thought they were closer tbh.
Appreciated
Reply to the thread, titled "Mira select ev shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
64degrees,
64degrees,
