View the thread, titled "Mira shower fail" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
R
Richie_77
Hi all
turns out that while mira bill the element a one size fits all..... It wont work with a working pressure greater than 5 bar and also doesn't like combi's 29cdi to be precise as they don't deliver enough hot water.
So now I need to find a combi friendly shower. Ideas plllllllease
Flow restricter that comes with it while worked gave in the performance of an electric shower hatdly impressive being that its coming off of a combi. In the end I did put a pressure reducer on the incoming and its sort of sorted the problem out custard is happy.
But question is what shower is the best with a combi a one size fits all without hurting the wallet too much
Standard bar mixer will do
If you like the style
or any shower that says it is rated for high pressure
The screwfix swirl bar mixer is a good budget device and at £60 odd youd be pressed hard to beat it
Russ
Reply to the thread, titled "Mira shower fail" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
