View the thread, titled "Mira sport electric shower stopped working" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Assuming that you've done L-N, L-E and N-E... is there an o/h stat?
Yes, checked L-N L-E and N-E all ok. Over heat not sure, not much inside the shower seems to be accessible. I have been looking for the manual online but not finding one that matches this shower. (My own shower).
Thermal cut out on those showers is at the top
of the wee cylinder & it is by far the most troublesome part & kills the power to entire shower. It seems to suffer from corrosion & this needs scraped off the top of cylinder before fitting a new cut out. Dead easy to test. Only about £11
Worth a shot, pcb is £130 ish for this!
Didn't realise they cut power to the whole shower, thought it was just the heat.
Solenoid will be also an easy to fit part & very low cost.
The latch switch (switch behind the on button) can fail also & you can remove it by prising the switch out of its place. It's just push on wire terminals. Switch is same black colour as its holder, but is a separate part.
Ok I'll check the the switch too. I think you just press one of the heat settings to turn it on and these a linked directly to pcb.
Reply to the thread, titled "Mira sport electric shower stopped working" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
