View the thread, titled "Mixer shower feed through heater" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi all.Could I feed an en suite mixer shower from a loft cold tank through an inline instant electric heater and twin impeller pump.If so would the pump go before the heater or after.I would appreciate any other idea's if mine is not feasible.
if your going to be using more than one outlet as a time start looking at the main / other things
whats your main atm lead blue etc ?
Personally with an electric shower already fitted, I can't see a reason why you cant run a mixer shower off the combi. Your heating running most of the time through winter doesn't matter, you'll only be running the shower for 10 mins at a time at most so your heating won't be off for long.
If your concerned about flow rate during multiple outlets been used, then maybe consider adding a header tank and cylinder and adding an extra zone to your heating to feed your extra shower/bathroom. Then you can have your pumped mixer.
Made up systems rarely work as you’d wish
Ok thanks for help
Reply to the thread, titled "Mixer shower feed through heater" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
