View the thread, titled "Mixer tap in kitchen - no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
M
MisSyD
I can not get the water from the mixer tap in the kitchen to heat up, even though the taps in the rest of the house are fine and heat up! Though if I turn the heating on it will heat up. Is this an abvious problem?😕
Please help!
Thank you
flow rate not enough through kitchen tap,make sure spout end clear and isolation valve opened correctly under sink,sometimes restricted to prevent to much splash up from sink bowl, could also be first sign of flow diagram on its way out in boiler
imho
Reply to the thread, titled "Mixer tap in kitchen - no hot water" which is posted in Bathroom Advice on Plumbers Forums.
