View the thread, titled "Mixer Tap Problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
W
wadste
I have an old mixer tap that is leaking quite badly from the centre lever. I have tried taking the leaver off by removing the centre bolt but can't seem to pull the lever off even when the bolt is removed. Any ideas?
pull harder!
build up of 10+ years of limescale is quite something so it will be stuck pretty well.
failing that easiest to get another tap
Thanks Tom
Reply to the thread, titled "Mixer Tap Problem" which is posted in UK Plumbers Forums on Electricians Forums.
