View the thread, titled "MLCP Fittings dripping" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Has anybody had any experience of MLCP fittings leaking? I’ve used tweet top fittings on a few decent sized jobs and had zero issues, however I’ve just been to a job I’ve done and 3 fittings had a very small drip on them, crimp gun has been calibrated etc and pipework has been correctly deburred,
Has anybody else had any problems?
Cheers!
Cheers for the reply.
25mm and 20mm, worrying because we’ve just done a big job that’s about to be boarded next week, pressure tested to 5 bar and all seems fine just worried a small leak will happen in the future!
Never had an issue and installed miles of the stuff fully inserted ? All oring there you using u jaws ?
That’s what I wanted to hear, yeah using the u profile jaws, it’s in abit of a crawl space which was awkward to work it so I’m wondering if it’s maybe dislodged one of the o rings pushing the fittings on, I love using the stuff so was hoping no one else had issues with the fittings etc! I’ll get a pic next time I go, it’s a very small drip. Not a constant drip more just a small build up on the fitting if that makes sense! Was just abit paranoid about the big job we’ve just done in it but should all be fine. Thanks for replying mate
Just to put your mind at rest I did a test removed all the oring and pressure tested upto 10 bar not one drop held fine
So yes sounds like it’s dislodged one of them and it’s not in fully or something else
You sure it’s not condensation?
Definitely not condensation mate it’s clearly on the fitting, like I say I’ve used it loads and not had an issue but this has got me thinking that maybe the fittings weren’t the best quality even though they seem great, I think we’ve probably just struggled to get the pipe in square and dislodged the o ring, I’ll just have to move on from it I think!
Shaun,
The job we’re doing at the moment in tweetop, I’ve pressure tested at 5 bar and not had a drop, would you expect a leak to show its self at that pressure straight away.
Paranoia setting in!
Shaun,
Oh yes you would see a drop I’m guessing you left it for an hour etc ?
Yeah will just do that and move on! Glad to hear you rate the fittings it’s horrible when you start doubting the quality of materials when you’ve installed so much of it!
With the amount they make your bound to have a bad fitting once a year etc as we’re only human at the end of it
Yeah was at 5 bar for an hour and left at 2 bar after that and is still full at that, im just hoping they won’t drip later on but all you can do is test and move on isn’t it, just over thinking it after the ones dripping on the other job,
Thanks for putting my mind at ease mate it’s much appreciated, have a good weekend 👍
Reply to the thread, titled "MLCP Fittings dripping" which is posted in UK Plumbers Forums on Electricians Forums.
