View the thread, titled "Mono Mixer Tap - cold water supply only" which is posted in Bathroom Advice on UK Plumbers Forums.
F
fatmax
A relative wants a small basin mounted on the wall in a grd. level toilet. There is only a cold water supply to this room and they are happy to just have cold water run to the basin. Can a mono mixer tap be used without having to blank off the threaded hot inlet?
fatmax
Thanks Ch4, I did wonder if this was the case but I couldn't find anything out about the internals on-line. Will a single pillar tap cover the larger hole?
Just get a wash hand basin with a single tap hole - they are cheap enough and designed for a single pillar tap.
Reply to the thread, titled "Mono Mixer Tap - cold water supply only" which is posted in Bathroom Advice on Electricians Forums.
