H
HIGHKIT
Hi, i'm new to the forum.
I'm a kitchen and bathroom fitter in the glasgow area but have a problem with my lpg combi in my static caravan in the lake district.
It,s a morco feb 24e. Three years old.
Hot water side is fine. But the heating side is playing up.
When demanding heat the pump starts right away but she does not ignite. Switch it off and on a couple of times and the fan cuts in and she fires up. It will run away quite content but sometimes it will cut out and only the pump will be running.
When she is set to go on by the clock, the pump will start at the correct time but not fire up.
Switch it off and on again and it will run for the timed duration.
Changed the pcb but just the same. Could it be the heating thermistor?
Any ideas?
Cheers
stewart
could be a lot of things can you post up the manufacturers instructions(MI,S)so we can see its innards?
Give Nigel the tech guy at Morco a call on 01482 325456, he's a good guy and can strip an feb down in minutes.
