View the thread, titled "Morco feb24e LPG Combi boiler not working" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
Jonny5
Hi, new to the forum but was hoping for some guidance.
My dads boiler has packed in and I was hoping for some ideas on how to diagnose the fault please.
The boiler won't stay on for either the CH or hit water. It fires up for a few seconds and then goes of (fan sill runs, which I presume is a purge cycle). The odd thing is that there are no fault codes. Water pressure is fine 1.5bar).he had disconnected the LPG supply to test the low pressure cut our / no gas supply and the fault comes up fine on the panel. After reconnecting the gas again and resetting the boiler he opened the hot water tap and the boiler ran for longer - water became Luke warm. The CH side was no different tho and the boiler will not fire on CH demand.
Pump is working. Can anyone offer any thoughts on the fault or things we can try to diagnose? I don't understand why we are not getting a fault code.
jon
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Morco feb24e LPG Combi boiler not working" which is posted in Boiler Advice Forum on Plumbers Forums.
