Guest viewing is limited
most common thing said
View the thread, titled "most common thing said" which is posted in UK Plumbers Forums on UK Plumbers Forums.
i was going to re-decorate but i thought i might as well wait untill the works done " as the 30year old stained wall paper falls of the wall"
My ideal boiler is not working
You must be loaded
Hot waters going hot and then cold
My boiler is not working,pipes in roof are leaking,tank over flows,waste under sink leaking,rad valve sticking,system requires flushing,need new guttering,sink taps dripping.........................It should only take you a few minutes...:angry:
BG said it needs flushing.
"You turned the radiator right down". "I explained why and it wasn't leaking when we left it." "But it leaked when we turned it on." (A 45 year old radiator valve). "Why do you want £30?" (with a 60 plated range rover sat in the garage). "I'll pay you next time you visit."
"HOW MUCH, for that little bit"
"But its only taken you 10 mins to fix it, it took the last engineer 2 hours to do it!"
And my personal favorite,
You plumbers earn a fortune!!!!!!!!
Reply to the thread, titled "most common thing said" which is posted in UK Plumbers Forums on Plumbers Forums.
jackyp1234,
PlumbBobBob,
