850Rick
Ive read some where that its possible to replace the guts in the motorised valves how true is this?
How is the painting & decorating course going Rick ???????Ok thanks im at college at the minute.We was talking about these valves as well.Im led to believe that 2 port valves are mainly used in bigger properties with space more than 150 square feet
NO, because I (like you) like a laugh & luv life !!!!!You ever considered joining the sparks forum Chris 🙂 🙂
Well you can replace the balls and motors on the honeywells for a fraction of the cost. If you could be bothered that is!You def can get parts for the inside of some of them, but it prob will cost same or more than complete body.
You can change the synchron motor but always check the operation with a pair of grips first. If it moves freely then change motor. If not then looking at a full valve replacement or possibly a flush which obviously depends on state of sludge in system which can affect operation.....it can be a good up-sell
Sounds like you have a top lecturer there.
If you have the patience or inclination, you can strip it down to its component parts (a good way to learn how things work) and change anything on it. There are only 3 parts that can go wrong, well 4 if you count the spring. It is not rocket science.
Unfortunately it is seldom like that in the real world where it comes down to time and money.
Usually changing it takes more time and you get more money and the customer sees what they paid for (which they like).
Sometimes tho, you just don't have the time so you repair it in 5 minutes :smile:
Were you in the SAS? lol
Do you think there is alot of gravity fed systems still about
Not sure about other makes but with Honeywell then if it has only 3 wires then it is a diverter.Is there any easy way of knowing which 3port imotorsied valve is what by looking at it?the 3 port mid position valve and 3 port diverter valve are surposed to look the same lol from i read.
Reply to the thread, titled "Motrised valves" which is posted in UK Plumbers Forums on Plumbers Forums.
