View the thread, titled "Moving a boiler - pipework help please" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Bunker
Hi chaps
Im putting a new boiler (oil) across the other side of the garage. Pipework used to look like this:
The system has a:
F&R for upstairs rads
F&R for downstairs rads going upwards as all rads on drops
F&R for HW
Fill is 15mm
Vent is off the HWR in 22mm
My mate who ususally helps with cases I cant get me heed round is selfishly off having a hernia sorted so its up to me at the last minute. Below is what I was thinking (ignore the position if the pump and valve, its not to scale):
Does this look about right? Any comments/ critiques would be welcome.
Thanks.
draw a plan of whats there now coming from the ceiling. Mark all the pipes with a marker then cut them all out...
hang new boiler and run pipes to suite new boiler can you not get a top fed unit????
looks like you got your work cut out there youll be fine mate have a cuppa..no biggy id love to be able to come and watch.lend a helping hand ill bring the jaffa cakes
just make sure you pop your vent and feed in right with the pump at the neutral point to save any problems down the line
Ok, I worked it out, joined up the 3 returns, and 2 CH flows. I added a new vent direct to the tank. A 15mm full bore lever valve at the boiler dumps nicely when you find a weep here or there 🙂
Oh and went 28mm out of the boiler.
Ignore wiring, all replaced.
Condensate straight through wall into downpipe.
I appreciate this is normal work for you guys but this is my first solo big re-jig, usually my boiler replacements are more straight forward.
You gave yourself a lot of room for the pipe work lol🙂 is the fire vale still good then 🙂 nice first solo job mate 🙂
next time put some spacers on the clips so you can get the insulation on the pipes
Hope condense is going to combined drain not soakaway, as per Building Regs?
Reply to the thread, titled "Moving a boiler - pipework help please" which is posted in Boiler Advice Forum on Plumbers Forums.
