View the thread, titled "moving central heating radiator." which is posted in Central Heating Forum on UK Plumbers Forums.
hi.i'm repositioning radiator in bathroom but there's no isolating valve on pipework..after i've turned electric off to the boiler and drained down the system will i still be able to have a shower,fill the kettle while the radiator is re-plumbed in the new position.thanks
If you drain the systrm down on a combi you wont be able to have a shower fed from the combi. You will be able to fill the kettle though
You could still operate the boiler if you have isolation valves for the heating system under the boiler.
Switch them off and refill the boiler. You should have hot water then.
thanks.i'll try to find them
[automerge]1594229394[/automerge]
thanks.tea more important than shower.haha
[automerge]1594230655[/automerge]
i found the isolation valve.theres 5 pipes coming from boiler.3 are 22mm and 2 are 15mm.the isolation valve is on one of the 15mm pipes.i can only see the one.i think it might be a cold water pipe 'cos it's a lot darker coloured than the others.is this the one i need to turn off before draining down the radiators.thanks
Reply to the thread, titled "moving central heating radiator." which is posted in Central Heating Forum on Electricians Forums.
