C
chriskent
Hi, i currently have a cold water tank in the centre of my loft above the landing walls that i would like to move to the side as its in the way. I understand the concept of having supporting walls to support the heavy load of the tank but need on advice on an idea i have. The tank currently sits on 20mm plywood which then sits on 2 x thick wooden beams, these 2 beams then sit on top of 2 x hanging beams. This is obviously the best place in terms of support, not so much for accessibility. My question is this, is it ok to put the water tank on 20mm plywood which sits on the 2 x thick wooden beams which then sits across multiple joists above 1 supporting wall? Will the joists hold the weight of a 50 gallon tank? I have attached some crudely made illustrations to show where i would like to put it.
Existing Setup
New Setup
Many thanks, Chris.
Existing Setup
New Setup
Many thanks, Chris.
