View the thread, titled "multyfule boiler , when pump is on water umps out of vent in to tank ???" which is posted in Boiler Advice Forum on UK Plumbers Forums.
a few details , for above post , fitted a multy fuel boiler 2 pipe system open vented , 28 mm pipe 3 rads and pump, when pump is on water pumps out vent in to tank, possable relocation of vent to other side of pump ?????????? if any one can help it would be much aprecated cheers rt
Is it possible you could sketch some sort of diagram as after a few glasses of ribena this is tricky to understand?!!
PS - hopefully your plumbing is better than your speling .... !!! teehee!!
Reply to the thread, titled "multyfule boiler , when pump is on water umps out of vent in to tank ???" which is posted in Boiler Advice Forum on Plumbers Forums.
