Myson Actuator Issues
View the thread, titled "Myson Actuator Issues" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Robaxter02
I have UFH heating downstairs installed new just over 2 yrs ago but I think one of my actuators isn't working. When the stat is turned on the red indicator doesn't lift so I'm thinking the actuator is damaged. The flow meter is working for the room when you remove the actuator but something's just not right. Currently it's way too warm sitting at around 25deg. Is this a simple actuator change out? Is there any way I can check to see if there is any other problems? All other rooms work fine. The system is on a 10 way manifold of each of the zones and the pump is working fine when I adjust the room stat.
The actuators are fairly cheap, so first port if call, would be change it. After that, it could be the valve passing. Removal and a clean should sort that.
Hi Robaxter02,
you are correct, looks like an actuator is gone.
The reason why there's so warm now in that room is because there's no actuator to restrict the flow to that circuit.
Please let me see the photo of your manifold and I'll see if I can supply an actoatur for you.
Thanks Guys,
I appreciate the feedback. I've actually ordered an actuator (24v) to suit my system but thanks for the offer Wojtek. I'll let you know if I manage to get it fixed.
Thanks Guys,
Reply to the thread, titled "Myson Actuator Issues" which is posted in UK Plumbers Forums on Plumbers Forums.
Robaxter02,
Robaxter02,
