View the thread, titled "myson midas "b" boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
pummer67
Hi
I have a Myson midas "B" boiler.
Does any one know much about these not many peple seem to know anything about them.
I have a slight problem with the central heating of the boiler which is intermitent. Once it is up to temperature its fine and will run on and on. Hot water is always fine.
I have a basic knowledge and have gone as far as i can with it.
Any one who knows anything about these or who thinks they could help me please contact me.
Mark
Blimey.
I am surprised that there are any of these left. I remember supplying a site of 36, and 27 of them failed on installation. I don't think Myson made them for long before being bought by Potterton.
Sorry I can't help you with it (I'm not gas registered) - the only thing I can remember about them was that they had twin pumps, instead of a divertor valve, which may or may not be relevant. Maybe a problem with the pump on the CH side?
lots of parts for the midas are hard to get if your desperate heatteam baxi pottertons service division may work on it,personally i would not as its a heap TBH
wow so i have been lucky so far then. the only part i needed to change on it has been thermocouple and i think the shop said that was the only part available. We have been in our house for six years and it has always worked well. you are correct it does have two pumps but i dont htink the pump is the problem.
when you first turn heating on it is like the gas is being held back as it is not a full flame in the heat chamber. the ch pump always runs staraight away but sometimes the gas will not ignite but you can hear a relay or something ticking continuously. to get the heating to work i run hot water which gives a full flame in the heat chamber and this makes the heat exchanger hot and then once hot tap turned off the ch pump will run for few seconds and gets heat up. i do this several times over course of 5-10 minutes and then eventually ch will run with full flame in the chamber and thern will work again till morning. occasionly if you leave ch pump running it will heat luke warm and guage says 30 degrees for about half hour to hour and then eventually the flame will ifnite to a full flame and heating kicks up to 60 degrees within few minutes.
i havent really got money at moment to replace so any ideas would be greatly appreciated.
mark
check the back of the pcb for a dry joint near the bottem, used to fitt these a long time a go still have the fault finder some were, so you know when I look for it I will not be able to find it
ok will have a look. thanks. let me know if you find fault finder. that would be really helpful.
Reply to the thread, titled "myson midas "b" boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
