View the thread, titled "myson not powering up" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
Notebook
Hi
pilot light on
turn on central heating
room stat up
boiler stat to high
I can hear a click/clang
hear what sounds like pump running
boiler however doesnt boot up, just pilot light.
any help appreciated.
first,turn pilot out and then re light see if then operates
then as pump working ,pursume power to boiler, therefore possible boiler thermostat faulty or solinoid on gas valve,probably gas valve
obviously check boiler not hot/reached temperature and water not circulating
can hear the gas valve click - thinking back after what you said - last time it happened to me I cleaned off the thermocouple.
will try
thanks
Reply to the thread, titled "myson not powering up" which is posted in UK Plumbers Forums on Plumbers Forums.
