View the thread, titled "Mysteriously overflowing cold water storage cistern.." which is posted in Bathroom Advice on UK Plumbers Forums.
A
Aquafix
Hi can anybody shed light on why the cwsc in the loft space keeps over flowing, it has had a new part 2 float valve fitted and seems to be in working order yet it still keeps overflowing, it is a open vented system, venting into the cwsc but the problem doesn't only happen when there is a call on the heating, so not down to venting.
Any help appreciated
Is the header tank higher than the cold water cistern? Could be a split coil in the cylinder. Alternatively a mixer tap or mixing valve on tank fed hot, mains cold letting back. Run off some hot water and then feel the cold feed, if you feel the hot back up it it's likely one of those problems.
Mike
Reply to the thread, titled "Mysteriously overflowing cold water storage cistern.." which is posted in Bathroom Advice on Electricians Forums.
