View the thread, titled "NCS - filling loop and electric cable, condensate discharge pipe?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bassmonster
I've not seen this type of filing loop? is it an old type thingy or some form of improvisation?
also, the electric power cable seems to have a dodgy connection and is going behind the pipes...is this ok as i would personally never do that as it's next to pipes that become very very hot..
oh, and the condensate trap discharge pipe is what seems to be like from a washing machine
thank you.
(i'm working towards my ACS)
The terminal strip is a shocker.... The quick fill looks ok as I presume the longer of the valves has a built in check valve.
Wire looks to be too close to the gas pipe(should be 25 mm +).
Where's the safety valve pipework?
What's a safety valve pipework?
Which If any unsafe situation would the wire be classified as?
I'd class the cable as NCS, but the terminal strip is shocking, should be wired properly or hidden in a junction box.
The safety valve pipework may also be known as the pressure relief valve pipework or safety blow off?
If the condensate hose is not the manufacturers proper hose then that's another score against it.
the boiler is a Baxi combi 105he. these were discontinued back in 2007.
so if the wiring is NCS and the condensate trap too, does that mean it would equate to AR?
No - Ncs no matter how many are just ncs
been a few years but 2 AR's on a open flued appliance is upgraded to id, that's the only time you 'add' them together to go to the next level. Somone please correct me if I'm wrong ;-(
been a few years but 2 AR's on a open flued appliance is upgraded to id, that's the only time you 'add' them together to go to the next level. Some please correct me if I'm wrong ;-(
You are correct
There's no way I would walk out the door and leave that cable like that it would take 10 min to run a new cable from the spur back to the boiler
If the landlord agree to it of course otherwise I would id the boiler
can you classify something external from the boiler and its parts under the unsafe sitituations proceedure? or does it come under another part some other regulations
You are incorrect.
Two or more NCS's relating to open flued appliance flue & ventilation may be upgraded to AR if you deem them serious enough. It is at your discretion.
Why would you ID this?
Would u leave a live cable exposed like that cause I wouldn't it's up to u at the end of the day .
You are incorrect.
I was always told 2 ncs on either flueing or ventilation would make it AR nothing about just on open flued.
You advise the responsible person that there is an electrical fault that needs to be addressed urgently and put it on your paperwork. Its not a gas fault so you cant use gas unsafe procedures to turn off the boiler. If you are an electrician as well I would imagine you could through electrical regs.
anybody notice the weird looking joints on the flow and the gas? no way are they 22mm sockets
Like I said its up to the person what u do
To be honest I would just put it right for the sake of a bit of cable before I left take 5 10 min and a clear conscience to boot
Are you going to AR a room sealed appliance for flue term too long, not sealed round wall and no terminal guard?
Unless anything has changed in 4 years from my last ACS applies to open flue flue and vent issues only.
It is still at your discretion. I resat mine 2 years ago and I spoke to the gas safe bloke about it as my thing was no terminal guard and flue hole not sealed so how can I AR that and thats when he said about your discretion.
Reply to the thread, titled "NCS - filling loop and electric cable, condensate discharge pipe?" which is posted in UK Plumbers Forums on Plumbers Forums.
