R
rafalkrupa
hello all. I have small problem. In loft i have 2x 55gallon water tank
And unfortunately both tanks wasn't install correctly with lids, screened
Overflow etc. In result I have a lot of debris and other sh*t inside.
Can you tell me ref. What will be cost to replace or if possible cleaning old
Ones? I have to say is impossible to drain off tanks through taps, and loft
Very small.
Silly Q. but have you turned of the stopcock to the property or isolated the tanks to stop them filling? once youve done this syphon the water out with a hose or empty it by hand. Clear the debris and refill. If one of these tanks is for heating which i assume dont drain down the tank through your radiators or that debris will cause potential blockages.
