View the thread, titled "Need advice with new downstairs toilet / sink - Waste issue" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I
icemancomeths
Hi all,
I am pretty much a novice and on a budget hence why I am trying to do the work myself.
I wish to convert a downstairs utility room into a toilet and a sink. Currently I have running hot and cold water so that's not the issue. The issue is with the waste.
There already is a waste pipe (4cm) going into the outside Soil Pipe (10cm), this was the old washing machine waste pipe.
My questions are this:
1. Can the Toilet waste be fed through this 4cm pipe?
2. If not then what tools / steps are needed to cut a 10cm through a brick wall then into the soil pipe?
I hope I'm not too vague and appreciate your help.
you will have to contact building control as it a new toilet install not just a replacement
Hi all,
I wish to convert a downstairs utility room into a toilet and a single pedestal sink. Currently I have running hot and cold water so that's not the issue. The issue is with the waste.
Hello Icemancomeths,
Yes this is sufficient for toilet waste.
No need to such things
as this was initially posted almost 5 years ago I would hazard a guess that the work has been done by now.
And you ain't getting a toilet waste through a 40mm/4cm pipe unless it's attached to a macerator.
Reply to the thread, titled "Need advice with new downstairs toilet / sink - Waste issue" which is posted in Boiler Advice Forum on Plumbers Forums.
