View the thread, titled "need some help regarding pipework" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
R
reeves1985
Re fitting bathroom and replacing rad with a suitably sized towel rad
It's staying along the same wall as the existing rad was but slight different location
The wall is a timber stud wall so the plan was to bring the pipes up in the wall and run to rad using angled valves
BUT
I have a bit of a problem whilst running the pipework in my head I have seen the stud wall runs parrallel right next to the floor joist. There's maybe 50mm from joist to wall
So I can't lift the board to get access to bring the pipework up
i'm sort of stuck for inspiration on a way around it
There is no chance a can get access from the other room as that has just recently been done and don't fancy making a small job bigger
Advice please
Forum won't let me add a pic to the post for some reason
//i60.tinypic.com/29wllxl.jpg
I can't upload a pic as the forum won't allow me to it denies the post
Plugs cut may work but what would I do about the unsupported boards under the stud wall
I imagine the OP problems is the joist & stud wall are parallel & only approx 50mm space.
This means the floorboard is either going to be a slow job to cut, or a multi tool needed. No big deal.
But piping to below the centre of stud & up are perhaps the real problem as can't get in below stud & could be done if the stud was notched in to centre. That would weaken stud but it could be strengthened by fixing each side to floor, if plasterboard is to be removed anyhow.
Sometimes ive seen me take the board up which is the easy part but when you dont have the 50mm and the joist is right below , i usually take a holesaw and cut a small hole in joist so i can solder a bend onto the vertical pipe , ( stand by with the extinguisher )
Lol! Have done similar but not really recommended for anyone not too confident or competent.
For any where there is a small distance to joist from edge of stud, a 30mm hole in centre of stud base & out of place solder 2 pieces copper with an elbow & later hook it through to the space near joist.
Thanks guys sorry my replies are comubgvthrough a bit garbled as I am new they need moderating first
In regards stud work and plasterboards they are no problem as I am a plastered by trade
My initial thinking was use a hole saw to cut a hole then notch the bottom plate of the stud to get access and screw bottom plate to the floorboards
All is a bit tight though
I may have to notch the joists which I was trying to avoid but still have the issue of running it into the wall
Can you push the pipes in from anywhere out side the bathroom ? Might be easier and less likely to kink or do an awkward solder!
Hi there do you have any "lift" in the pipes ie will they move up and down? if so lift up and clamp pipe
with vice grips to stop it dropping cut pipe close to floor solder on a couple of elbows channel floor to take pipe into bottom stud and then take pwk to desired location within partition.Alternatively lft floor room side of pipes and do the same chanelling floor.Good luck..brum
Yeah there is lift in the pipes so I could cut at floor level and push down
There's no way I could do it from the landing and slide it in
I didn't mean to push underfloor.cut a chase in floorboard 20mm deep back toward bottom stud also into bottom stud use a drill with 20 mm bit and tidy up with chisel this chase is where pipe will end up beneath floor level the lifting of the pipe prior to cutting just makes it easier to push pipe down for each pipe use 2no elbows either end feed or yorkie its kinda hard to explain but ive done it loads of times..brum
Reply to the thread, titled "need some help regarding pipework" which is posted in Gaining Plumbing Experience on Plumbers Forums.
